H3 heat Blend door gear pushed in stuck on cold
Old Jan 18, 2023 | 02:47 PM
@Hummer3!'s Avatar
Default H3 heat Blend door gear pushed in stuck on cold
has anyone ever replaced the gear for heat blend door on a H3. All actuators and climate control are good. the is no female part inside the heater box.
Old Jan 20, 2023 | 11:49 AM
Welcome to HF.
Couple things. Please READ before you go posting.... the New Member Section clearly tells everyone that it is NOT For Tech Questions, but for intros only. I moved it for you to the H3 section where H3 tech questions go.
Next, please avoid digging up OLD Threads just to tack on your new question. READ: Old Threads/'Necro-Bumping'
Old Jan 20, 2023 | 12:24 PM
650Hawk's Avatar
Not on an H3, but I repaired a broken blend door on the rear heat/AC unit on a Tahoe. Used JB Weld and a metal rod to repair the broken shaft. Worst part was gaining access, something that is likely to be a problem on the H3 as well.
Scotts H3 Hummer
Apr 10, 2022 02:47 PM
FordFanatic1988
Dec 23, 2021 05:35 PM
IUB33
Jun 11, 2019 09:35 PM
Vaulk
Jun 6, 2018 08:44 PM
