Broken Blend Door? No Heat - A/C & 3 Actuators OK- Cave of Despair HELP!
Old Apr 27, 2021 | 07:15 PM
stavok's Avatar
Default Broken Blend Door? No Heat - A/C & 3 Actuators OK- Cave of Despair HELP!
Hi,
Noob here ran into a H3 project and trying to revive her. HVAC was completely dead when purchased. After some fuse replacements and system recharge A/C is now up and running blowing cold. Panel controls working except temperature control has no effect on air temp. Both heater hoses at firewall are hot so I believe core is hot. All three actuators seem to work fine though I'm not positive of their correct positions for given temperature switch position. Deflection to various vents control and actuator works great. Removed the aft most actuator (the "Heat" one?) and it rotates nicely and on command.
So I think the problem is obvious and ugly. There seems to be no female receptacle for the actuator shaft. Please see photo of suspiciously dark and empty hole where actuator shaft should engage? I can stick most of my pinky tip into the hole and feel nothing. A larger blade flat screwdriver finds no purchase while jigging the hole at various angles.
Anybody ever get this deep into the dash and how the blend door is mounted in the HVAC assembly? Seems the blend door is loose somewhere in that inaccessible cave :-(
I've kludged a blend door before but this one I'm struggling with how to route the new actuator string/wire/tape/dowel/paperclip/.
Hints are most appreciated.
Blend Door Female View - WHERE ARE THE COGS?
Old Apr 27, 2021 | 07:23 PM
Old Apr 27, 2021 | 07:47 PM
stavok's Avatar
Yes please. No need to ask for consent- just administer help asap! Cheers.
Old May 1, 2021 | 09:42 PM
stavok's Avatar
Bump? Sure is lonely in this cave.......nobody has ever run into this one before?
Old May 2, 2021 | 02:31 PM
check on a gm parts website for one of the parts inside the air duct like the blend door. they usualy will have a exploded view diagram. maybe it shows what is missing on the diagram.
Old May 2, 2021 | 06:22 PM
You can get a better view with a borescope.
Old Jan 16, 2023 | 04:45 PM
@Hummer3!'s Avatar
you are not alone I have the same issue. how did you resolve?
Old Jan 16, 2023 | 04:46 PM
@Hummer3!'s Avatar
were you able to resolve?
Old Jan 17, 2023 | 06:53 AM
He/She is probably not going to respond.
STAVOK: Last Activity: 07-02-2021 11:45 AM
Post up your questions in a new thread.
humminchrome
Aug 14, 2022 01:03 AM
apollo18
Aug 25, 2020 01:11 PM
Vaulk
Jun 6, 2018 08:44 PM
MidTNHummer
Jun 12, 2015 08:35 PM
johnnyballistic
Nov 19, 2008 06:00 PM
