Fuel Pressure Issue H3 Alpha with Codes
Old Dec 16, 2019 | 05:34 PM
  #21
P069E Description:
The fuel pump control module uses the serial data network to signal the Engine Control Module (ECM) that the fuel pump control module is requesting malfunction indicator lamp (MIL) illumination. A DTC is set in the fuel pump control module, and the request for MIL illumination is sent when the fuel pump control module determines that a failure that affects emissions has occurred in the fuel pump control system. When the ECM receives the message from the fuel pump control module, DTC P069E will set in the ECM.
14515B
Old Dec 16, 2019 | 06:20 PM
  #22
Old Dec 18, 2019 | 10:19 AM
  #23
daniiel777's Avatar
Thanks hummerz if that doesn’t work ill try that. Looked at the module and it wasn’t even very dirty but who knows what it’s like inside
Old Dec 18, 2019 | 03:39 PM
  #24
Did you check the recall I posted above?
Old Dec 18, 2019 | 03:58 PM
  #25
oceanbrave
Oct 6, 2019 11:44 AM
Katb895
Apr 10, 2019 09:51 PM
djbit
Dec 2, 2011 10:14 PM
palmxjjsi
Jul 26, 2011 01:12 PM
dscaberboy
Jan 27, 2009 06:28 AM
