differential lock panel illumination...
Old Jan 23, 2024 | 10:32 AM
teahead's Avatar
Default differential lock panel illumination...
anyone know if they take the same bulbs as behind the HVAC *****?
I have a light out (4wheel HI LOCK).
I used these bulbs from superbrightleds.com for the HVAC illumination, but curious if same bulbs are used for the locking control panel.
NEOx LED Bulb - High Power Instrument Panel LED
SKU: NEO4-NWHP
Color Options
Natural 3800K
Old Jan 23, 2024 | 10:51 AM
brothapig's Avatar
They are not the same lights. And unfortunately, they are not a socket design; they are soldered direct to the board.
When I had a light go out on me (4-HI), I moved the light from behind the diff-lock area to the 4-HI spot. My truck does not have a locker, so I obviously did not need that light (they must all have the standard electronic board, with a different button face).
In your case you don't have that option, but perhaps you could get one from a local junk yard? You will need to de-solder and re-solder the bulb in place.
They are tiny blue lights with very small wires. think of a (much smaller) Christmas tree light bulb (the old ones you could replace).
EDIT:
was able to find a picture from another forum (Serv 4wd | Hummer4x4Offroad)
Old Jan 23, 2024 | 01:32 PM
teahead's Avatar
Uggh...dang it.
Wish I knew what bulbs they are and I'll try to de-solder, re-solder a new bulb.
Old Jan 23, 2024 | 01:34 PM
teahead's Avatar
Probably can be found here, but no clue which one to get:
https://www.jkllamps.com/incandescent/wireterminallamps
https://www.jkllamps.com/automotive/autowireterminallamps
Old Jan 23, 2024 | 01:48 PM
teahead's Avatar
Interesting. This other thread shows they look a bit different:
Old Jan 23, 2024 | 02:05 PM
teahead's Avatar
Seen this on the net:
Old Jan 23, 2024 | 02:07 PM
teahead's Avatar
Ken06H3
Mar 27, 2023 10:15 AM
Ken06H3
Apr 6, 2020 12:16 AM
a7m1
Jun 6, 2014 06:45 PM
hummie07
17
Feb 9, 2012 07:49 PM
