Replacement bulbs for 4x4 control panel
Old Apr 20, 2020 | 12:04 AM
Ken06H3's Avatar
Default Replacement bulbs for 4x4 control panel
Looking for the bulb type to replace the 4x4 control panel bulbs.
Disassembled unit, but nothing except they are soldered and have a blue cover.
The HVAC info found in the Forum is spot on.
I cut short strips of a tie wrap to help with opening the housing, made it easier and no broken tabs.
Nearing the end of my project to convert to LED lighting. Thanks,
Old Apr 20, 2020 | 12:44 PM
H3Luxembourg's Avatar
Hey Ken06, you can find them easy on Amazon and E bay and they fit.
Old Apr 25, 2020 | 02:12 PM
wfturner's Avatar
Like H3Luxembourg states those bulbs are available.
The actual type of bulb is a T4.
I have changed out my bulbs a number of times and finally got LED bulbs of the same T4 style
and then soldered them in and wired them in parallel with a small resistor so as to have them less bright.
No bulb failures in quite some time.
Amazon Amazon
Good luck
Old Apr 28, 2020 | 01:15 PM
650Hawk's Avatar
Are the bulbs in the HVAC controls, instrument panel, and door window switches the same T4 size?
Old Apr 28, 2020 | 02:54 PM
scoreh3's Avatar
Yes . I recently replaced my window control lights and HVAC lights and they are the same bulbs.
Old Apr 28, 2020 | 02:55 PM
RKSmith163's Avatar
If you don't have the time or skills to change those, the entire assembly is pretty inexpensive OEM new. Make sure you get the correct configuration.
Old Apr 28, 2020 | 07:33 PM
Old Apr 28, 2020 | 10:47 PM
Ken06H3's Avatar
Appreciate the help. That parallel resistor is what I overlooked. I installed white T4/T4.2 Neo Wedge LED Bulbs and they are bright.
FYI - Replaced the interior 578 with 211-2 578 LED Bulbs, Xtreme Super 6000K and they light it up like crazy.
Thanks,
Old Apr 29, 2020 | 06:50 AM
wfturner's Avatar
Thanks,
The resistor you use should be in series, not parallel
Old Apr 29, 2020 | 10:39 PM
Ken06H3's Avatar
The resistor you use should be in series, not parallel""
Got it, Thanks again
