Replacement bulbs for 4x4 control panel
Old Apr 30, 2020 | 07:08 AM
wfturner's Avatar
Originally Posted by Ken06H3
The resistor you use should be in series, not parallel""
Got it, Thanks again
Good luck with the wiring, I love the LED bulbs white light for the 4 wheel drive modes.
I ended up using a 470 Ω resistor for cutting down the brightness
Old May 23, 2020 | 11:47 AM
Mathieu Chartrand's Avatar
Default H
Hi i just want To make it clear i just changed and got spare bulb left so the 4x4 control mod. Are the same size than the hvac and window door control
Old May 27, 2020 | 03:25 PM
650Hawk's Avatar
Originally Posted by scoreh3
Yes . I recently replaced my window control lights and HVAC lights and they are the same bulbs.
I found out that the passenger side window control uses a very odd bulb. Those T4/T4.2 do NOT work; the contacts are on the "side" of the base rather than the surface.
Old May 27, 2020 | 04:09 PM
What bulb did you purchase?
Old May 28, 2020 | 02:02 PM
650Hawk's Avatar
This is what I got for the drivers side switch. But the plastic bases wouldn't quite fit; the circuit board is just a bit too thick. So I removed the LEDs from the new base, and installed them into the stock bases; pretty easy. I really like the color/brightness; white but not too bright, very similar to the backlighting on the headlight switch.
My passenger side switch bulb is still ok, though not quite as bright as these new LEDs, so I opened that up to replace it as well, so as to match. That's when I found out the difference. I looked closely, but couldn't really come up with a way to use the new LED (short of soldering, which I CAN, but didn't really want to), so I left it as is. If it burns out in the future, I'll address it then.
Old Mar 24, 2023 | 09:35 PM
JEFFREY KRAUS's Avatar
Did you ever find the correct bulb for the passenger front switch? If so, please share a link or part number. I have the same problem.
Old Mar 26, 2023 | 05:17 PM
Passenger front switch bulb is different.
Old Mar 27, 2023 | 10:15 AM
Digging up THREE YEAR OLD THREADS to ask a question? Not necessary
w3sCiH3
H3 Frequently Asked Questions
Oct 12, 2020 10:18 AM
Ken06H3
Apr 6, 2020 12:16 AM
TacoDeMaiz
Mar 14, 2020 08:24 PM
ludwig75
Feb 10, 2020 07:23 AM
Major Tom
Oct 17, 2013 09:10 PM
