Instrument Climate Control Backlight Bulbs
Old Mar 12, 2012 | 06:01 PM
w3sCiH3's Avatar
Question Instrument Climate Control Backlight Bulbs
Where Can I Fin Bulbs For The Instrument Climate Control (Air Condition ***) Backlight
Old Mar 12, 2012 | 06:35 PM
wfturner's Avatar
Several of us here have had this problem
I bookmarked this link, that takes you thru the process
good luck
https://www.hummerforums.com/forum/h...removal-16478/
Old Mar 14, 2012 | 09:08 PM
HawaiianH3's Avatar
Old Mar 15, 2012 | 07:50 AM
2wheelmonster's Avatar
Anyone know of an LED ?
Old Mar 15, 2012 | 07:56 AM
Broken Halo's Avatar
I haven't tried this myself, but this post from Hummerat is from the thread that started it all.
https://www.hummerforums.com/forum/h...78/#post223259
Old May 16, 2012 | 01:08 AM
mattmjm's Avatar
Old May 23, 2012 | 07:37 PM
Toddman33's Avatar
Default Replacement bulbs for hummer h3's
Go to www.superlumination.com Tail Light Brake Light Turn Signal LED Bulbs. They carry all automotive bulbs you need a new edge type B bulb for you climate controll module, they sell them for 1.50 a piece or 3.50 for a led version. I've replaced these in my power window switches and climate control module myself as they went out they're easy to do and cheap to replace just takes time and little patience. Hope this helps
Old May 23, 2012 | 07:39 PM
Toddman33's Avatar
It's a neo wedge type B bulb, sorry spell check messed that up....not new edge
Old May 24, 2012 | 11:11 AM
mattmjm's Avatar
Just installed the bulbs from this eBay seller yesterday:
Light Bulbs for 2005- 2010 HUMMER H3 Heater Climate Control A/C Backlight 037495768993 AUTO AUTOMOTIVE CAR BULB LAMP INCANDESCENT BULB NIGHT TIME TEMPERATURE VENT SWITCH DASH UNIT PART FAN HEAT HVAC TEMP BUTTONS BACK PANEL ILLUMINATION LAMP NOT LED A
Replaced all 3 of my AC/Heater control **** bulbs. They match the stock OEM bulbs perfectly 1:1. I know the link won't stay good for ever, but I recommend getting them while they're available and holding on to them as they will inevitably be difficult to find when you need them!
Old May 25, 2012 | 03:59 AM
Toddman33's Avatar
Wow you got screwed they're only $1.50 a bulb so $4.50 on www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs! I believe I posted that earlier this week as well. That's why eBay stinks
