Cylinder 5 Misfire at idle P0305 & P0420
Old Dec 2, 2025 | 02:37 AM
  #31
MadDogBimmer89's Avatar
Originally Posted by Justinh
Sounds like the culprit. What is the "case relearn" process?
What Doc said along with plugging in a compatible bi-directional scan tool that allows crankshaft angle position error (case) relearn/reset, whatever you want to call it. Just followed the scan tool prompt which involved revving the engine to 4000rpm etc. until it said success or you're out of beer. I'm not sure if there's any other way without the tool, but I believe it's recommended anytime you replace the crank sensor.
Old Dec 2, 2025 | 10:22 AM
  #32
Well it looks like we have another Happy Ending just in time for Christmas. Congrats MDB89!
Old Dec 10, 2025 | 04:12 PM
  #33
Just when I thought the problem was solved, had another crank no start after heat soak. Given that I've replaced pretty much everything I shifted my focus on the ignition switch per hummerz recommendation, rather than cleaning it, I just replaced it to make sure. Problem persists. No issues starting when cold (most of the time) and no issues starting when hot (all the time) sitting and letting truck heat soak for 10-20min and it hesitates to start (sometimes). I'm starting to think cylinder #5 is toast, which tracks with my previous symptoms over the last few years, truck running hotter than normal, low oil pressure, etc. adding external cooler for the transmission helped mask the symptoms, but didn't fix the root cause which was likely low oil pressure leading to cylinder 5 running hotter than it should, causing rings to wear more than others, eventually leading to low lower compression.
Old Dec 10, 2025 | 06:22 PM
  #34
Stay strong!
Old Dec 12, 2025 | 04:22 PM
  #35
I've ran 2 cans of seafoam through the intake, haven't done one through the fuel tank. What does it do when added to the fuel?
Old Dec 12, 2025 | 05:39 PM
  #36
What it does:
  • Removes deposits: Uses detergents (like PEA) to break down and clear carbon buildup on injector nozzles, intake valves, and combustion chambers.
  • Restores fuel spray: Cleans clogged injectors so they spray fuel in an optimal pattern, ensuring proper atomization.
  • Improves combustion: Leads to more complete burning of fuel, reducing wasted gasoline.
  • Lubricates system: Some formulas also lubricate the fuel system, reducing friction and slowing future buildup.
This video demonstrates the cleaning process and results:
Related video thumbnail
03:36
Key benefits:
  • Better fuel economy: Corrects inefficient fuel delivery, saving gas.
  • Restored performance: Fixes poor acceleration, hesitation, and rough idling.
  • Smoother operation: Eliminates stumbling, misfires, and stalling for a smoother ride.
  • Reduced emissions: Cleaner combustion leads to lower harmful emissions.
This video explains why using a fuel injector cleaner is important:
59s
When to use it:
  • As a maintenance item, periodically (e.g., every 1,000 miles or as recommended).
  • When noticing symptoms like reduced MPG, sluggish acceleration, rough idle, or engine hesitation.
  • For modern Gasoline Direct Injection (GDI) engines, which are prone to carbon buildup, a specific GDI cleaner is often recommended.
This video provides a guide on how to use fuel injector cleaner:
Old Dec 12, 2025 | 10:01 PM
  #37
What it does:
03:36
[img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAAAAAB WESUoAAABTklEQVR4AX3NIayCUBiG4bfPTDnFaLFvdoONGU8Pb jQKwchmMxgJ5tPtgUa1nmYm0HfKdwcwuDLwDX969v1oLJS32MD W3itNjaBOmSJv5iBnVvEF6h3zOIYJeJaKmgGohmURBrBjpbgHV 1ZzEvrcy37CVmdIqhNdRQkQhC5eb9quyuChhLaNlLRMBPzwJVP aggttd4U3YESJV63NHNT+oS3gueF1UjUDR+VGBeCI8eKl9Bu8B L4BrpgWEMI3UAU3neAMHbio/A/S7qoEBkAlm07grTTLko9gw7YHhGYCRkM5FjuATPUICtnIGIM8O fcB8NYImpqulyJHxacHkZRBoQSrJ12xnh5xc3Rd3AmsO5K4PX2 FE8r50VOo4UcSUsFqZQd0ZKVEPQgRix00ADWL4hBGoBAv749Ac swq9Q0UCsPY3kkjmPLuemZjc/fR1B8CKX3ii55/LwAAAABJRU5ErkJggg==[/img]
[img alt=""]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAA f8/9hAAAAcElEQVR4AWP4//8/RZh6BgCZAkDsAMUNWDFCXgDFACCV8J/B+D8pGKwHRAKRAUyQDEMMQAYEUGBAAsiABpwKHjz4/9/BAZ8BDXgNgIMNGyg04MABkg1AeCEgAK8XKA5EiqORooSELykXE JuUBz43AgAIA1ZhBoG9vwAAAABJRU5ErkJggg==[/img]
NATES INTERACTIVE AUTO
YouTube • Nov 4, 2020
Key benefits:
59s
[img alt=""]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBwgHBgkIBwgKCgkLDRYPDQwMChsUFRAWIB0iIiAdHx 8kKDQsJCYxJx8fLT0tMTU3Ojo6Iys/RD84QzQ5OjcBCgoKDQwNGg8PGjElHyU3Nzc3Nzc3Nzc3Nzc3Nz c3Nzc3Nzc3NzQ3Ny83Nzg3NzczNzc3NzQ3Nys3NTc3Nzc3N//AABEIACAAIAMBEQACEQEDEQH/xAAaAAACAgMAAAAAAAAAAAAAAAACBAMFAQYH/8QAKRAAAgEDAgUDBQEAAAAAAAAAAQIDBBEhABIFBjFBURMigWF xobHBFP/EABcBAQEBAQAAAAAAAAAAAAAAAAADBAL/xAApEQABAgUEAQIHAAAAAAAAAAABAAIDETFBUQQSIYFhocEFE3 GRsdHx/9oADAMBAAIRAxEAPwDjjHREBPXREBOcD40RRk9fv186Irmh4dF UUks9RO8RADRqkYYsu9UJNyMXcW+zeNZoscseGtE8/Yn2/CvDghzS4mX9l7pyu5ZWikmilrGZ4mjV2FONibywUk7r2uuTY9R 11CHr/mAENrO/PFbKr9JsJBNJWz2p+J8t0fpU0fD6lDUBWEzSbgrFdxY2AJ7HuB 7cX1ODrXzcYg4tS8pY/fK7iaVkgGHla7X8NqKN33qJI12kyxXMdmAIz5sRrfDjMiDjg4u sj4TmJ+LjKCmSGopmcpCIQyT7AFDq4uNpzdBnv4vnUXaU7i5rr zpOxGfKo2ONsiPHrNXlDznStxKeoq6LYJ1j9QmfcPYxIsNv1J+ O2sMT4a8Qw1jqTtntama1peS4Vl6dJSLnCGGaJ4+FhfTeVwP9Q sTJe4PszbcdVPw5zgQX1lbHa4GsAIIbm+ekjUcwiXh7UsdIY19 IwIDUllVNwOVtYtfocdsYGrs0e1+8uvOl/rjwpO1M2bQPFVSG5Atm56edbVlQ5IbIv5/miLKg3AtbwD+9ERAH89fOiL//2Q==[/img]
4DIYers
YouTube • Jun 23, 2017
When to use it:
My fuel injectors are brand new, I'm gonna try seafoam in the tank and see. Thanks 👍🏻
Old Dec 13, 2025 | 09:40 AM
  #38
Justinh's Avatar
Sea Foam doesn't have PEA in it, just to be sure.
Old Jan 10, 2026 | 05:06 PM
  #39
Tuffy's Avatar
Default misfire
I had a nagging intermittent misfire on my 2007 H3. After replacing coils, plugs, testing all the injectors, doing the Seafoam top engine clean and super injector flush, checking the intake gaskets, I started going through the wiring harness to the coils, starting at the coil and following the individual wires down. All the conduit was disintegrating leaving some wire exposed, there was one tiny nick in the power wire
for #2 causing it to ground out on the valve cover and cause the misfire. Super annoying going through all the wires but it feels so good when you find the problem. Cost like a dollar to fix it with some heat shrink.
Old Jan 26, 2026 | 06:47 PM
  #40
That was going to be my next stop as I'm still misfiring despite all the stuff. Cylinder 1 looks like already had the connector and wire replaced at some point.
