Cylinder 5 Misfire at idle P0305 & P0420
Old Jan 26, 2026 | 07:14 PM
  #41
Originally Posted by MadDogBimmer89
That was going to be my next stop as I'm still misfiring despite all the stuff. Cylinder 1 looks like already had the connector and wire replaced at some point.
Are rodents making nests in your H3?
Old Jan 26, 2026 | 09:37 PM
  #42
MadDogBimmer89's Avatar
https://youtu.be/cyy8W9MNdIY?si=OOftxfdv3b-K3OCbH
haha no rodents, but the wire conduits around the car just crumble. I've been replacing them where I can.
Just traced the wire from cylinder 5 coil, don't see any exposed copper, not to say there's isn't an intermittent break somewhere inside the wire. That damn air box sure keeps things snug in there and could have potentially pinched a wire, saw a few sharp bends. I'm about to rip that thing out and install something more practical that gives me easy access to wiggle the wire around while the truck is running.
Old Jan 27, 2026 | 02:44 PM
  #43
Did more digging today to try and pin point when I get the misfire. Looks like I only start to misfire once engine is at full temp, in park, AC off. If I turn the AC on or put the truck in D misfire goes away, in other words engine load at 20% = cylinder 5 misfire, engine load between 25-30% no misfire. LTFT and STFT normal, manifold pressure normal, I couldn't tie engine RPM to misfire, but it seems to fluctuate between 660-690
Old Jan 27, 2026 | 05:33 PM
  #44
To me it appears to be sticking valve I've corrected on my 3 with induction cleaning & only refilling with TOP TIER™
https://cimg4.ibsrv.net/gimg/www.hummerforums.com-vbulletin/781x379/i5_28bca6c91a9eeb3df8583783ace49ee64aa512fb.jpg
Old Jan 27, 2026 | 11:21 PM
  #45
https://youtu.be/O5N_Z1W6mho?si=zQg8bkCgKu_Qxetq
I'll just have to keep at it, will do another round of cleaning. What is this random image of a valve cover you sent?
Old Jan 28, 2026 | 07:30 PM
  #46
Map to cylinder----> #5 Btw, monitor condition/change engine oil/filter.
Old Feb 26, 2026 | 08:04 PM
  #47
Quick Update:
Still misfiring in cylinder 5 - bought a pair of gauges to do a leakdown test, cylinder 5 leaking 40% mostly via rings as I can feel air more noticably blowing from the PCV and oil dipstick tube, hardly anything from the intake and exhaust. Which further confirms my wet/dry compression test I did earlier that strongly pointed to rings not sealing well.
Gonna try another b12 and mmo soak to try and free things up, otherwise I'm probably going to sell the darn thing. I thought about buying a crate engine and swapping that in, but kinda over it at this point.
Old Feb 27, 2026 | 09:57 AM
  #48
Spanovich008's Avatar
Default Engine Restore?
As a last resort/Hail Mary, you could change the oil, try a slightly thicker viscosity (10W-40 for instance) and add in a can of Engine Restore.
For the I-5 I would try the 6 Cylinder formula. This might seal things up enough to restore some lost compression and rid the Misfire, but then again it might not.
Old Feb 27, 2026 | 10:57 AM
  #49
That's the plan, luckily the misfire is not terrible only triggers CEL once in a while, but shows up on the scanner nevertheless. I did read about engine restore and some folks used it with good results, but idk about using higher viscosity oil, it does get very hot around these parts during the summer so maybe it won't be so terrible.
Old Feb 27, 2026 | 04:24 PM
  #50
>>>>>>>>>>0W-40 motor oil
Mobil 1 FS 0W-40 or ESP Formula
0W-40 motor oil
0W-40 oils are recommended by automakers for many types of European vehicles, including Mercedes-Benz, Porsche and Volkswagen. The viscosity is gaining popularity with American automakers for high performance engines in both cars and pickup trucks.
In this viscosity, we offer Mobil 1™ FS 0W-40 or Mobil 1™ ESP Formula 0W-40. They can be used in either gasoline- or diesel-powered engines.
If your diesel-powered engine requires an oil meeting the CK-4 specification, then choose Mobil Delvac 1™ ESP 0W-40. Note: We don’t compare diesel engine oils with motor oils formulated for gasoline-powered vehicles.
Mobil 1 ESP Formula 0W-40 carries the dexos®2 approval specified for General Motors vehicles.
