Brake question
Old 01-29-2020, 09:22 PM
Giboo's Avatar
Default Brake question
Daughter calls this morning and says your car has no brakes. I get it home, not leaking fluid anywhere. I see air bubbles coming out the driver side brake line. Get a new line, take the old off and no fluid in it. No fluid leaked when I took off the metal line to hook up the new one. Tried to bleed the line and only air comes out. The fluid is not getting into the line but my wife said it was building pressure. So something else is not working and I need some help figuring that out. Any ideas on why no fluid is coming out when I bleed it?
Old 01-30-2020, 03:51 AM
Happy Hummer's Avatar
Have you tried reverse bleeding? Also, does the other side have fluid coming out when trying to bleed?
Old 01-30-2020, 08:23 AM
Giboo's Avatar
After I changed the line, I didn't have time to check because I had some place to be at a certain time but when I was looking for the problem, the other side had fluid. I will double check tonight. When I loosen the four lines on the master cylinder, fluid comes out.
Old 01-30-2020, 09:00 AM
If there isn't any fluid in the line and there is fluid coming from the master cylinder there must be some sort of blockage in the line between the master cylinder and the brake line connection you put the new line on.
Here is the basic system and how it works. A little more complicated than the old PS Booster with the addition of StabiliTrak.
Hope this helps ya.
Old 01-30-2020, 09:48 AM
Look into the GM brake line recall for info. Basically the flex brake lines suffered from unexpected advanced corrosion and some had to be replaced. Corrosion can build up to an obstruction if significant enough.
jwmingus
06-18-2015 05:25 PM
H24U
05-21-2014 09:10 AM
gotafish
04-16-2012 06:45 PM
Bornabe
08-20-2011 08:28 PM
rjohnson67
07-15-2010 11:13 PM
Quick Reply: Brake question
