brake fluid
Old Jul 14, 2010 | 07:30 PM
rjohnson67's Avatar
Default brake fluid
Hi there, I was wondering if anyone has used silicone based brake fluid on their H2 before? I heard from a friend that it performs well
Old Jul 14, 2010 | 07:55 PM
DJINCO's Avatar
I wouldn't.
I have found that 1) it is not compatible with the DOT3 or DOT4 fluids so you would need to really flush the brake system before using DOT5 (synthetic)
2) DOT5 is for vehicles w/o ABS, unless
3) the vehicle is specifically designed for DOT5 synthetic fluid.
BTW, that web site is not brake fluid. That fluid is for everything from antiperspirant to hair care.
Cheers, Doug in Colorado Springs
Old Jul 14, 2010 | 10:52 PM
TBarrow's Avatar
Silicone based Cannot be used with ABS.
DOT4 - ATE Super Blue or Gold. The color difference is so when you flush the system you can see that it is completely changed. I used this on my Viper and Porsche 911 for the track. We were required to flush it every 6 months. Brake fluid is the most overlooked fluids in a vehicle. It should be flushed at least once a year for street vehicles.
Great brake fluid makes a difference.
Old Jul 14, 2010 | 11:17 PM
TBarrow's Avatar
Racing Brake Fluid
Brake Fluid is rated by dry boiling point (for fluid fresh out of the bottle) and wet boiling point (for fluid saturated with moisture). If you bleed brakes frequently, the dry boiling point is most important. If you do not change your brake fluid often, the wet boiling point becomes more important. All of our fluids except AP600 will mix with DOT 3, 4, and 5.1 fluids. None of the fluids we carry are compatible with DOT 5 (silicone) fluids.
http://www.pegasusautoracing.com/gro...pID=BRAKEFLUID
Old Jul 15, 2010 | 11:56 AM
85_305's Avatar
Banned
Ahhhhhhhhhhhhhhhhhahahahahahaha..
Phew. That was seriously funny. You'll have to forgive me for laughing at others pain.. but that wasn't a link provided by the original poster. That was an automatically generated hot-link for advertisement
Old Jul 15, 2010 | 11:13 PM
rjohnson67's Avatar
okay, thanks. I'll look into switching to that.
jwmingus
Jun 18, 2015 05:25 PM
gotafish
Apr 16, 2012 06:45 PM
Bornabe
Aug 20, 2011 08:28 PM
HummerHummer.co.uk
Sep 10, 2009 11:44 PM
KUMMER
May 31, 2008 10:31 PM
