H2 Dot3 brake fluid, can I add Dot4
Old Sep 9, 2009 | 05:20 PM
HummerHummer.co.uk's Avatar
Default H2 Dot3 brake fluid, can I add Dot4
Hummer H2 - As above guys, it says DOT3 on the filler cap and I have gallons of DOT4 spare. Can I mix the two or stick to DOT3. Any help/advice appreciated. Thanks in advance.
Old Sep 9, 2009 | 05:32 PM
calif phil's Avatar
Yes dot 3 and dot 4 are compatible. Dot 4 is even better. It has a higher boiling point than dot 3.
Old Sep 9, 2009 | 08:08 PM
08H3's Avatar
They may mix chemically, but if I recall correctly, DOT 4 is more prone to moisture contamination. There is a very detailed writeup on this on one of the other Hummer boards. Sorry, but I do not have a link to it right at hand.
Old Sep 10, 2009 | 05:00 PM
Thanks guys for the reply. I was really hoping to use what I had, but will look into it. Thanks again.
Old Sep 10, 2009 | 11:44 PM
DOT 3 and DOT 4 brake fluids are essentially the same except for their respective boiling points. They can be mixed with no adverse effects. You would be better off to bleed and flush your system and go to all DOT 4 if that is what you have. Brake fluid does get old, carries moisture, etc after time/use.
jbs45
Aug 8, 2011 05:36 AM
HummingRightAlong
Jun 17, 2010 04:16 PM
KUMMER
May 31, 2008 10:31 PM
dschwarzw
Jul 2, 2007 09:04 AM
MRDM1
Apr 23, 2007 10:09 PM
