Bought my first Hummer and it’s unfortunately throwing a few codes. Need some advice
Old Sep 21, 2023 | 08:39 AM
  #21
Never came across a bad one of those yet, and being able to wiggle it a bit at the Intake Manifold is OK. If it was an issue, it would be a different code.
The other one under the Resonator Box to the top of the Right side Valve Cover often rot out and crack (like you described) and eventually leak. Any 1/2" Emission Hose cut to length can replace that one.
Easy stuff first: clean the Gas Cap Gasket and filler tube mating surface.
Old Sep 24, 2023 | 03:57 PM
  #22
Tonyp25's Avatar
First do the fix for clogged sunroof drains. Finally, a fix for clogged sunroof drain tubes If the passenger floor got wet, so did the BCM which will need an inspection for corrosion and harness connection to evaluate for possible replacement.
Then replace the OEM Battery Terminal Connectors (if not done already) with a quality aftermarket set like Stingers or your favorite brand.
Hey Doc, I replaced the terminal connectors with the below stingers (SPT53501). I cannot for the life of me get the connector to be flush with the battery on the positive terminal (which is slightly thicker than the negative). I can get it on if I take the tightening screw out but it’s then too small of a screw to fit back in….did I buy the wrong ones? Or perhaps the battery I bought has slightly larger terminals.
Stinger Connectors on Amazon Stinger Connectors on Amazon
Old Sep 24, 2023 | 04:27 PM
  #23
You need to removed the terminal adapter ring inside the Postive(+)terminal.
Old Sep 24, 2023 | 05:12 PM
  #24
Tonyp25's Avatar
I could not be more dumb. Thanks. Fits perfect now.
Old Sep 24, 2023 | 05:50 PM
  #25
Not your fault. Stinger Terminals in a set, includes 53501 negative (-) and 53502 positive(+)
Old Sep 25, 2023 | 01:23 PM
  #26
Now you learned that + and - Battery Terminals are NOT the same size. Next....................
wpage
Nov 8, 2019 10:39 PM
Usedhummerh3
Oct 31, 2018 10:23 AM
mgurgone
Sep 3, 2014 02:02 PM
ibbe14
Apr 11, 2012 07:49 AM
scottballz
Dec 30, 2008 05:24 PM
