Blower motor issue
My blower motor continues to run with the engine off. I replaced the blower motor resistor but the problems persist. I thought about possibly replacing the blower motor relay but can't find the relay anywhere, i checked the fuse boxes and don't see one.
This is a very common problem, not sure what year you have, but for a 2005's there isn't a blower motor relay, pretty sure yours will be the same.
The Blower Motor Control Processor (commonly called a "Resistor") has a single Blower Motor Speed Control input and two outputs to the blower motor, thats all (other than GND and VBATT)
So either the pulse-width-modulated input is somehow running flat-out (unlikely) or your replacement module is also faulty, where did you get it from?
Replacement controllers are hard to find, there's actually a repair service on ebay but you can do it yourself usually just a case of replacing the power MOSFET (IRFBA1405PPbF) search on ebay or RS Components.
Close to this very thread is this one which goes into more detail.
Keep us posted.
ObeyWW
May 29, 2018 10:55 AM
EVILKING
Feb 12, 2015 05:49 AM
dan385
Feb 25, 2014 05:27 PM
