Stuck in 3rd gear!! Key gets stuck in ignition. Help 😔
Old Apr 21, 2019 | 07:13 PM
Stephaniehemminger's Avatar
Default Stuck in 3rd gear!! Key gets stuck in ignition. Help 😔
I was going up a hill today and I got stuck, it was like I was starting off in 3rd gear and it wont upshift or downshift from 3rd. Just started today, I have no clue, and can't afford to put it in a shop. And have any insight???
Old Aug 24, 2019 | 08:23 AM
Blue2004H2's Avatar
Default It’s most likely the transmission fuse in the fuse block under the hood
Had the same problem with my 2004 H2 it was a fuse under the hood. Pop off the cover, flip it over and read the fuse box diagram and find the transmission fuse. Pull it out and check if it’s burnt out. As for the key sticking its related to the shifter control harness on the bottom, possibly just a broken wire on the harness connector.
Hope it helps
Joe
Old Sep 1, 2019 | 04:33 AM
Ceejack2's Avatar
Did you check the linkage that connects your transmission to the cable shifter.
Old Sep 16, 2019 | 02:34 AM
Jennitran's Avatar
Originally Posted by Stephaniehemminger
I was going up a hill today and I got stuck, it was like I was starting off in 3rd gear and it wont upshift or downshift from 3rd. Just started today, I have no clue, and can't afford to put it in a shop. How to check car fuses with multimeter, visit Autofthings for more infor if you concern. And have any insight???
It could be bad ignition switch. Take a look of it and change if necessary.
Old Sep 16, 2019 | 08:10 AM
Ceejack2's Avatar
Default Transmission linkage
Make sure the transmission is linkage is connected. There's a plastic connector underneath on the driver's side next to the transmission. That connector breaks sometimes & won't allow you to shift or take the keys out. It's an easy fix.
nncanfarelli
Aug 4, 2019 09:27 PM
Pirate Maden
Feb 19, 2019 09:33 AM
Duke Sherman
Sep 23, 2017 12:04 PM
Amanda Reusch
Aug 30, 2016 09:24 PM
lbzvegas082
Jul 21, 2010 07:17 PM
