H2 key stuck in ignition
Old Mar 1, 2010 | 05:25 PM
lbzvegas082's Avatar
Default H2 key stuck in ignition
I was in some pretty deep snow a few weeks ago "trying" to see at what point I would get stuck (having fun more or less) and after I was done I could not get the key out of the ignition and I am able to shift gears without the brake pedal. I found the release button in the steering column and use a screwdriver to get the key out everytime, however it is getting Annoying. Anyone had this problem or can tell me what I broke?
Old Mar 1, 2010 | 05:33 PM
BTW...it's not stuck in park, the battery is not low, the battery is not draining, and I have read this https://www.hummerforums.com/forum/s...stuck+ignition
Old Mar 1, 2010 | 05:45 PM
and there are no broken wires under the console.
Old Mar 7, 2010 | 09:35 PM
drtom's Avatar
Banned
Default no help but im watching
im curious how they do it in h3, it comes out ONLY when it is ALLOWED to , right gear pos and key position.
kind of messy if u want to turn off and pull dash with no juice on and pull shift back out of the way.
is it a mechanical link with shifter, a cable??, maybe broke??
the key has to be off,? and it MUST match up with a shifter cable release,,,notch, so im guessin its a cable?!!!
how do u do it with a screwdriver??
lets tear YOURS apart and find out!!!
tom
Old Mar 7, 2010 | 10:29 PM
HumminNBoatin's Avatar
Sounds to me like a bad ignition switch. This happens pretty often in the H2.
Old Mar 9, 2010 | 02:02 PM
It is now intermittent (comes out every once in a while). Still symptom of bad ignition switch? Tom- Read the link in the second post. You can manually remove the key from any GM ignition the same way I would imagine.
Old Jul 12, 2010 | 04:07 PM
tferrari95's Avatar
this happened to me and i took it to a shop that diagnosed the intr lock fuse under the hood
Old Jul 21, 2010 | 07:17 PM
Intercooled's Avatar
Happened to me and it was a bad ignition switch. Known H2 problem, at least on my old 05.
nncanfarelli
Aug 4, 2019 09:27 PM
hummerhonduras
42
Sep 19, 2012 11:49 AM
lbzvegas082
Mar 3, 2010 10:11 AM
ezspirit
Jun 29, 2009 07:13 AM
doyleh3
Apr 2, 2008 10:01 PM
