H3 blower motor not working
Old Mar 10, 2016 | 06:03 PM
Nate76's Avatar
Default H3 blower motor not working
Hi all. I'm new on here and have read most post regarding faulty wire harness and resistor. I replaced both harness and resis and blower still is not working on any setting... Any suggestions on hat it could be now?
Thanks in advance for any help.
Nate
Old Mar 10, 2016 | 06:23 PM
Jim_Davis's Avatar
there is a recall on these, call your gmc dealer and they will set you up to have it fixed.
Old Mar 11, 2016 | 09:02 AM
There is a revised harness part for the HVAC controls, that is what the recall is for. It does not include the blower motor itself, which could independently fail and need to be replaced.
https://www.hummerforums.com/forum/h...call-gm-35541/
Old Mar 19, 2016 | 08:09 AM
Nate76's Avatar
Ok just replaced blower motor and still not working. So far have replaced everything with the exception of control panel. Could it be the hvac control panel?? Also weird thing is when I put volt meter on blower motor leads is reads 12.4v but will not spin up motor. Hook motor directly to a 12v battery it fires right up. This is getting very frustrating..
Old Mar 19, 2016 | 10:15 AM
happythree's Avatar
12v ok, then you have an open ground wire, thats all
Old Mar 20, 2016 | 07:35 PM
WR3NCHE4D's Avatar
Check your basics. Happythree is right. Check for power and ground. Check your fuses. I believe there is also a relay near the resistor for the blower. I think this only turns on in the high position. Don't have a wiring diagram handy to help out more. The recall is for the wires burning up at the plug for the resistor. This may also be a problem.
Old Mar 21, 2016 | 10:31 AM
Nate76's Avatar
Thanks guys! Any suggestions on how to trace open ground wire? One thing i did notice is 12V is present at blower moter plug at lower speeds, but not on high (meter goes to zero..).. Like i said earlier, even with the 12V at the connector it will not run blower motor... May just have to take it to dealer at this point.
Old Mar 21, 2016 | 02:26 PM
happythree's Avatar
you should be looking at a wiring diagram. not hard to trace a connection problem.
to test,you can ground any contact on the resistor connector. thats what the switch does.
Old Jan 14, 2019 | 07:38 AM
stolly23's Avatar
Any word on if this was fixed?
Old Sep 28, 2019 | 08:26 AM
Michael J Maiello's Avatar
Default Have same problem with my fan motor
Changed everything
can’t find a solution
