BCM Issues
Old Apr 24, 2021 | 08:59 PM
  #31
Thatsgr8's Avatar
I verified the security light flashes once and only once when I use the RKE with doors all closed sitting in the drivers seat. I did reverify there is no voltage drop in the start position. Only click I hear is the Start/Run relay engaging.
Old Apr 24, 2021 | 09:02 PM
  #32
does the starter even work at all?
Old Apr 24, 2021 | 09:03 PM
  #33
Thatsgr8's Avatar
It does not turn over at all. Thats why there is no voltage drop. Before this electrical hell started it started right up all the time.
Old Apr 24, 2021 | 09:13 PM
  #34
There should be a voltage drop without starter, check/post voltage on both sides of #14 fuse.
Old Apr 24, 2021 | 09:23 PM
  #35
test the starter and test/ examine the engine grounds
Old Apr 24, 2021 | 09:24 PM
  #36
Thatsgr8's Avatar
I will do that in the morning when it's light outside. It died the last time pulling into my driveway. Hasn't started since.
Old Apr 25, 2021 | 10:34 PM
  #37
Dylan Rogers's Avatar
Unhappy
I can only imagine the frustration with this! Especially your experience with the dealership and such. I hope it all settles soon and you have some sort of break through on it.
Old Apr 27, 2021 | 09:20 PM
  #38
Thatsgr8's Avatar
I finally was able to go check fuses. Fuse 14 has "0" volts. I also checked fuses 13 - 35. no voltage present. Checked all the grounds in the engine bay and motor. I finally ordered the PCM. I should have it mid next week. I believe since the OBD plug comes back with "Error" and doesn't read. Other ideas? Thank you again for all of your help.
Old Apr 27, 2021 | 09:52 PM
  #39
Have you tried disconnecting, inspecting, and reconnecting the two connectors supplying the fuse panel (on the underside)? Maybe there isn't a proper connection there for some reason.
Old Apr 27, 2021 | 09:55 PM
  #40
Thatsgr8's Avatar
Not yet. I will try that tomorrow. Thanks.
