Battery suggestions
Old Jul 23, 2018 | 08:41 PM
Bone's Avatar
Default Battery suggestions
looking for the best battery, regardless of price, for my 2010 H3 Alpha. Want to use the factory case but willing to modify for fit. Only additional non factory options being powered is a trans cooler with dual fans, 2 engine cooling fans and supercharger coolant pump. Battery part numbers needed along with the suggestions.
Old Jul 24, 2018 | 08:34 AM
Quality aftermarket Battery Terminal Connectors are more important than the battery itself.
Old Jul 24, 2018 | 10:33 AM
Ordieh's Avatar
Odyssey pc1230dt
Old Jul 24, 2018 | 06:13 PM
wfturner's Avatar
Originally Posted by ordieh
odyssey pc1230dt
x2 . . .
Old Jul 24, 2018 | 06:32 PM
happythree's Avatar
Default jfwiw
i once ran an external 69 amp load on my 3.7 wiyh 13 v out. then drove it with my lawn tractor batt just to test,230 cca.
the generator will prob run it all fine
Old Jul 25, 2018 | 07:16 AM
Hey Bone, thanks for ALL of the HUMMER parts.
FYI:
An AGM Group 34 will fit in the stock battery box with slight modifications to the bottom of the battery box.
We decided to go with an AGM battery with higher CCAs, more reserve capacity and better equipped to deal with the physical OffRoad abuse plus winching and extra equipment (lights, CB, horns, amp, etc.). Better price than others with the same warranty and stats. Plus there are TONS of Autozone's around the US and Autozone will replace it no questions asked and your 3 years starts over again with a new receipt.
Autozone Platinum is made by Deka who is actually East Penn Manufacturing Inc. Yep Made in the USA!
Slight modifications to the bottom of the battery box is required. Dremel will do the job neatly.
Features & Benefits of AGM.
Duralast Platinum is an absorbed glass mat (AGM) battery designed to give you the ultimate combination of power, durability and flexibility. Delivering maximum cold cranking amps and reserve capacity, Duralast Platinum provides safe, reliable power to vehicles with multiple electronic accessories.
*Greater ability to recover from deep discharge than conventional batteries
*Designed to provide maximum starting power and deep cycle capability
*Advanced technology for vehicles with accessories that demand greater or instant power
*Constructed for greater vibration resistance and enhanced durability
*Leak proof and spill-proof for safer maintenance-free power
*3-year free replacement warranty
Product Details
Part Number: 34-AGM
Weight: 42.5 lbs
Warranty: 3 YR
Notes: Warranty consists of 3 years free replacement.
***750 Cold cranking Amps***.
120 reserve minutes.
Amp-hour: 55
Application: Automobile
BCI Cold Cranking Amps (CCA): 750
BCI Cold Cranking Amps Value: Tested to BCI Standard
BCI Designation: 34
Battery Height: 203 mm - 8 in
Battery Length: 273 mm - 10 3/4 in
Battery Width: 175 mm - 6 7/8 in
Cranking Amps (CA): 955
Positive Terminal Side: Left
Post Location: Top Post
Reserve Capacity (min): 120
Voltage: 12
Old Jul 25, 2018 | 08:28 AM
ozark1's Avatar
Thumbs up
New cable ends..and an OPTIMA battery..
Old Jul 25, 2018 | 11:27 AM
I used to be an Optima fan, until I put a Red Top in a 70 Olds that turned out to be a leaker. Battery acid/gel leaking onto the tray and onto the inside fender & quarter panel of a 40+ year old classic pisses me off! Took hours to clean that up, prime and paint the damage done.
Used to run them in my last boat too.
No Optima Battery in my future, ever.
Old Jul 25, 2018 | 11:40 AM
svxr8dr's Avatar
Originally Posted by wfturner
x2 . . .
Make that x3
curleymon
Jan 19, 2019 10:49 AM
scottH2
Jul 30, 2013 08:47 AM
Tech5
Mar 17, 2011 10:32 AM
Theuofmiami
Nov 13, 2010 09:27 PM
kdec19
21
Nov 3, 2008 10:10 AM
