battery dies overnight
Old Feb 25, 2011 | 06:07 PM
Tech5's Avatar
Default battery dies overnight
Hummer h2 2003 model
Battery keeps on dying over night
I charged the battery up and took the negative cable off and hooked a volt meter to the ground wire and the negative side of battery while positive cable is on the battery ... I get battery voltage from ground wire , I disconnected every fuse and relay under the hood and on drivers side panel and still has battery voltage
I also disconnected the ignition system still battery voltage any one have this same problem? or had
Old Feb 25, 2011 | 06:33 PM
Tech5's Avatar
Also disconnected the alternator and re checked same thing , the battery is a duralast and its around 3 ish years old I am going to replace it and re check but I don't think it's the battery . anyone else has ideas or known facts that causes this on this model?
Old Feb 25, 2011 | 06:41 PM
drtom's Avatar
Banned
u gotta check current,u will always read batt volts on a volt meter.
use a digital meter on 10 amp range.
normal is apx 110 ma.thats .11 amp,or 1 tenth amp,rowever u see it
Old Feb 25, 2011 | 06:46 PM
Tech5's Avatar
Why would you read battery voltage on the ground side and ground of a battery?
Old Feb 26, 2011 | 10:02 AM
Tech5's Avatar
UPDATE !!!
ok before all this happen I was playing with the ONstar because I just bought it and was checking to see if it was active and what not . So after playing with it , the next day bam my truck battery was dead . So after doing all types of test the only thing I could think of was the last thing I messed with in the truck . Glove box light wasn't staying on , nor gauge cluster . So I disconnect the ONSTAR as everywhere I read said a vehicle that is not using ON STAR should disconnect it . SO I did and over night I had about .11 volts drain which before it was 12.42 and now its like 12.31. SO that is normal and my problem is fixed thank you for those that tried to help!
Old Mar 7, 2011 | 10:57 AM
GirlieH2's Avatar
just went through that for about 3 weeks with mine - turned out the battery had a bad core so they replaced it (under warranty)...irritating as heck.
Old Mar 14, 2011 | 10:59 PM
luxh3's Avatar
had the same prob with my 07 h3... i had an aftermarket cd player in it and that was the problem... as soon as i put the factory cd player back in it the problem stopped, not sure if you have an aftermarket cd player, but if you do that could be the problem.
Old Mar 15, 2011 | 12:05 PM
drtom's Avatar
Banned
repeat,,,you will always have batt volts if you use any sensitive voltmeter. you must measure current with an amp meter. normal current is appx .11 amp. thats 1/10 of an amp or 110 milliamps.
if you dont understand this concept you need to get help from someone who does
Old Mar 16, 2011 | 12:56 PM
2wheelmonster's Avatar
Where can one buy a sensitive volt meter?
Old Mar 17, 2011 | 10:32 AM
drtom's Avatar
Banned
Default Where can one buy a sensitive volt meter?
walmart, $12
barry4x
Aug 2, 2013 07:56 AM
deebocubs
Oct 27, 2012 06:27 AM
john2006H3
Jul 29, 2011 03:45 PM
amir
Mar 28, 2008 11:19 PM
importkiller
Mar 2, 2008 12:01 PM
