Anyone replace their leafsprings
Old Aug 16, 2024 | 11:01 AM
  #21
The max on the front should be 23.5" or you will start tearing up stuff. After you adjust the T Bar on that right front, drive it around the block so to speak, then measure to allow it to settle into position.
Old Aug 16, 2024 | 03:12 PM
  #22
Ranger Tom's Avatar
I llowered the passenger side only, but the drivers side was going down as well. I adjusted the drivers side now both fronts sit at 23 and the rears are 24. I am not sure how much more I can crank up the drivers side. I had to use two very long wrenches for leverage to get is to come up. Could the torsion bars be worn out?
Old Aug 16, 2024 | 04:00 PM
  #23
Torsion bars are worn out when they break. You got it level side to side which is a key for handling control when driving. 23 fronts is what mine are set at for 12yrs and still all OEM factory installed front end suspension & drive train except for the shocks I replaced with Monroe reflex when I purchased. Drive on and enjoy the ride.
Old Aug 16, 2024 | 07:15 PM
  #24
No need to drive>>> JOUNCE. Same procedure used when performing a proper alignment.
Old Aug 18, 2024 | 03:26 PM
  #25
Ranger Tom's Avatar
Thanks for all the help.
Jpluta1
Oct 1, 2020 07:52 AM
Jpluta1
Sep 22, 2020 09:38 AM
mgurgone
Apr 1, 2012 05:30 PM
solarflare
Mar 23, 2012 10:54 PM
hummerray
Nov 8, 2008 01:06 AM
