Antenna removal or basic fix
Is the a way to remove the outside antenna cap ( i will call it ) my antenna rod inside the is all over the place so before I strong arm it off i thought I would ask inner wheel well is already off changing side marker bulb.
Jaws
Jaws
I believe once you remove the antenna mast, the plastic cap #2 should pop off, it is snapped over a lip of the spacer #4, behind the cap is a nut #3 that holds the base against the inside of the fender.
solarflare
21
03-08-2008 06:41 PM
