Antenna removal or basic fix
Is the a way to remove the outside antenna cap ( i will call it ) my antenna rod inside the is all over the place so before I strong arm it off i thought I would ask inner wheel well is already off changing side marker bulb.
Thanks Jaws |
I believe once you remove the antenna mast, the plastic cap #2 should pop off, it is snapped over a lip of the spacer #4, behind the cap is a nut #3 that holds the base against the inside of the fender.
https://cimg6.ibsrv.net/gimg/www.hum...ee711f3669.jpg |
Got it thank you
