Antenna removal or basic fix
Old Aug 16, 2018 | 02:48 PM
Aaajaws's Avatar
Default Antenna removal or basic fix
Is the a way to remove the outside antenna cap ( i will call it ) my antenna rod inside the is all over the place so before I strong arm it off i thought I would ask inner wheel well is already off changing side marker bulb.
Jaws
Old Aug 17, 2018 | 10:09 AM
I believe once you remove the antenna mast, the plastic cap #2 should pop off, it is snapped over a lip of the spacer #4, behind the cap is a nut #3 that holds the base against the inside of the fender.
Old Aug 17, 2018 | 11:48 AM
Aaajaws's Avatar
Got it thank you
staggs
Jul 14, 2012 11:27 AM
Romanzz
Jun 9, 2012 07:24 AM
Chameleon
Dec 31, 2009 07:46 AM
daniel5455
Jul 22, 2008 05:54 PM
solarflare
21
Mar 8, 2008 06:41 PM
