Airbag code B0092
Old Dec 2, 2024 | 02:30 PM
Mantiz67's Avatar
And, still no Year and Model (yeah we know it is an H3, but which model H3: Base, Adventure, Lux, Lux off road and not an Alpha?).
2006 Adventure...and why would that matter they are equipped with the same passenger presense sensor??
Old Dec 3, 2024 | 09:09 AM
The 2006 seats wire harness is actually different from appx. mid 2007 on. They do use the same sensors.
Thank you for the info, start looking for an Air Bag (SRS) Control Module. If you have a capable bidirectional scanner capable of programming the SRS Module and it fails to communicate, you found your problem.
If you are just getting an occasional air bag fault light, you can clear the BCM by placing the vehicle in Neutral, engine running, put one foot on the brake and hold it there, push the Emergency brake on with the other foot and release it, repeat the E brake and release 5 times fairly quickly. If the light stays off, it was a glitch. Happened to my 07 a few times a year until I had to replace the SRS Module. The E Brake clear works on BCM fault light, it may or may not actually clear a BCM code depending on what it is, it will not reboot/clear a BCM problem from a short or flash based corruption.
You could always try to clean all the contacts with the module and sensors while the battery is disconnected to see if corrosion is a problem with the offending circuit. I'm betting replacement module.
Good luck.
Old Dec 3, 2024 | 09:23 AM
Mantiz67's Avatar
Good luck.
Thanks for your help much appreciated 👍
Old Dec 16, 2024 | 09:25 AM
Mantiz67's Avatar
YEAR AND MODEL are always important!
Was it wired, or just left under the seat? Any chance the prior owner just disconnected it hoping codes would disappear?
Does this module if replaced have to be programmed?
Old Dec 16, 2024 | 02:34 PM
The SRS Module needs a bidirectional scanner like the Tech II.
Old Dec 19, 2024 | 02:01 PM
Mantiz67's Avatar
Do you happen to know the resistor value for the passenger seat presence sensor?
Old Dec 19, 2024 | 02:33 PM
Ah................................... no.
jshelby
Aug 17, 2024 02:21 PM
Eurynomestolas
Jun 8, 2023 10:10 AM
fastNYsix
Feb 15, 2022 09:02 PM
hummer_on_fumes
Jun 21, 2018 01:10 PM
WR3NCHE4D
Feb 7, 2016 10:38 PM
