B0013 error code
Old May 27, 2024 | 05:01 PM
jshelby's Avatar
Default B0013 error code
Hi all, new here and just wanted to see if anyone has dealt with this code before?
I recently replaced my front wheel bearings (7 years later) and when I was going to get the emissions test had several lights come on..I fixed those however the last one I have is the B0013 which is the passenger air bag fault but not exactly sure what this code means? There are references in the manual about proper voltage and resistance which I havent tested yet but wanted to see if anyone had dealt with this code before I start tearing things apart?
It is a 2007 Hummer H3 base.
Old May 27, 2024 | 06:19 PM
With my old 07 I ended up having to replace and reprogram the airbag module . The module was $600 and it is under the center console. It would not respond to programming communications so had to be replaced. That sucked!
Old May 27, 2024 | 06:30 PM
jshelby's Avatar
I was able to figure it out...If I move the passenger seat it will clear itself...there appears to be wire that disconnects under that seat and will have to do some investigation but it did clear fine just by moving the seat all the way forward...then back..then slightly forward again.
Old May 27, 2024 | 07:01 PM
Old Aug 17, 2024 | 02:20 PM
jshelby's Avatar
It is now intermittent...I will appear every so often but its not broke or fixed. It does seem to be something with the passenger seat as moving it will some times fix it for a while or putting weight in the seat will fix it for a period of time before it randomly comes back.
I would like to clear up this issue but since its not consistent its difficult to track down.
Old Aug 17, 2024 | 02:21 PM
jshelby's Avatar
Thanks for this. I will check this out.
fastNYsix
Feb 15, 2022 09:02 PM
Back40coffee
Jan 14, 2022 11:24 PM
ulthummer
Oct 11, 2021 11:23 AM
hummer_on_fumes
Jun 21, 2018 01:10 PM
mephis2012
May 4, 2015 10:21 PM
