GPF cleaning (gasoline Particular filter)
Old Nov 17, 2024 | 10:16 AM
ojh32008's Avatar
Default GPF cleaning (gasoline Particular filter)
Greetings Loyal ones and hummer lovers
I has an issue with engine oil leaking, I fixed it by removing the clog in the engine air outlet (near the check valve) after that all the previous problem are gone( smoky engine, oil leak)
the oil reached to the exhaust I have the feeling that the GPF is socked in oil and the engine air-intake area (throttle …etc)
Because i have to push the gasoline paddle to the end to get some power especially in offroad.
i need some advise and feedback how to fix and enhance my car strength
thanks
Old Nov 17, 2024 | 11:08 PM
Happy Hummer's Avatar
A focused explanation of vehicle history would be wise in getting possible assistance.
example:
20xx hummer h3
200,xxx miles
Trouble codes
Related parts information
Related repair information
Items in question
Etc.
Old Nov 18, 2024 | 09:38 AM
A GPF is a filter?????? If you say so. Problem is, H3s do not have a serviceable fuel filter, only a permanent screen at the in tank fuel pump.
More details, better answers.
Old Nov 18, 2024 | 11:16 AM
650Hawk's Avatar
Is he perhaps referring to the PCV system?
Old Nov 18, 2024 | 06:00 PM
Originally Posted by Justinh
What check valve?
I also would like to know what a GPF is.
GPF is an abbreviation for: Gasoline Particulate Filter, a device that reduces the amount of fine particulate emissions from gasoline-powered vehicles:
On this side of the pond we have Catalytic converters
Old Nov 19, 2024 | 04:48 PM
Justinh's Avatar
thanks
Old Nov 27, 2024 | 12:59 PM
650Hawk's Avatar
I'm not aware of a GPF on any Hummer H3. OP could be referring to the Catalytic Converter, but they are not the same thing.
Old Dec 20, 2024 | 10:14 AM
ojh32008's Avatar
I had a major issue in my beloved h3.
during a usual rough off-road trip in desert I retuned back then i found the radiator is mixed with transmission fluid. Unfortunately I had to rebuild the transmission and installed transmission radiator (truecole 30k btu).
Returning back to the subject,
i used wynns gpf cleaner but unfortunately the upstream o2 sensor was stuck three mechanics try to lose it up, but they couldn’t. anyway they open the catalyst then inject the cleaner. Then another issue appeared the upstream o2 sensor was not cleaned so misreading between the sensors appeared. I bought a new upstream sensor waiting to be installed. I have to figure away to remove the old sensor.
signature
h3 2008 adventure
167 k miles
Pres
Aug 15, 2022 11:33 AM
Stollo
Jan 27, 2022 01:50 PM
Pjxmotorsports
Jul 15, 2021 12:50 PM
user 956363738
Mar 6, 2017 11:38 AM
brunoso
Jul 18, 2013 08:53 AM
