Oil leaks
Old Aug 14, 2022 | 11:57 AM
Pres's Avatar
Default Oil leaks
My H3 IS LEAKING OIL FROM UNDER THE CAR THE MORE I ACCELERATE IN THE GAS THE FASTER OIL LEAKS. FROM EVERY WE'RE UNDER THE CAR WHAT IS THE ISSUE
Old Aug 14, 2022 | 11:59 AM
Pres's Avatar
Default Oil leaks
Old Aug 14, 2022 | 05:59 PM
Wrong forum, NO CARS HERE! Btw, how do you see"THE MORE I ACCELERATE IN THE GAS THE FASTER OIL LEAKS"?
Old Aug 15, 2022 | 11:16 AM
Justinh's Avatar
Loose oil filter or leaking oil pressure sensor? And check the VVT valve on top of the engine.
A little more info on where the oil is coming from would be helpful.
Old Aug 15, 2022 | 11:30 AM
Issue = Oil Leak.
Remove the skid plates, clean the oil off with rags/paper towels. Then start it after clean so you can LOOK and SEE where the oil/fluid is coming from.
Old Aug 15, 2022 | 11:33 AM
Also, DO NOT POST ANYTHING in the FAQ Section, just because you have an oil leak question does NOT make it an FAQ. Do NOT make more than one Thread about the same topic.
Posts once, then wait for responses.
kwoodoak
Oct 16, 2022 12:37 PM
ski.dive
Jul 7, 2019 09:20 PM
syphon
Jan 4, 2008 12:20 AM
