H3 Alpa need parts
Old Aug 12, 2022 | 11:02 AM
MaxClev's Avatar
Default H3 Alpa need parts
I have a H3 Alpha 5.3 liter V8 - I need the upper and lower fan shrouds/ the fan and a fan clutch.
Old Aug 12, 2022 | 01:00 PM
Welcome to HF Max.
I MOVED your Thread to the H3 section where ALL H3 Questions go. The HF Help & Suggestion Center has nothing to do with any vehicle, like where it says; "Need help with Hummer Forums? Have a suggestion to better HF? Tell us here!" Like where it also states in the Thread stuck at the top of the HF Help section: "This section of the forums is NOT for vehicle questions. It is where you can ask questions about HOW TO USE FORUM FEATURES ONLY!" It is for questions about how to use the Forums..... like "how do I post a pic?" stuff.
Finding the shroud ain't no big deal............... Ebay, GM Parts Direct, Google it.
Upper
GM 25862433
Lower GM 25862431
Pretty pricey for new ones.
Fan and Fan Clutch is even easier.
Old Aug 12, 2022 | 01:06 PM
MaxClev's Avatar
Default H3 Alpha parts
Welcome to HF Max.
Upper
GM 25862433
Lower GM 25862431
The fan and clutch are pretty easy to find...however I didn't find that to be the case yet with the shrouds...GM discontinued, eBay no luck so far....looking through wrecking yards at the moment. Thanks
Old Aug 12, 2022 | 02:39 PM
RVR's Avatar
RVR
That's likely to be problematic, as they won't want to sell shrouds from H3s not damaged in the front, but the entire front clip as one instead, and those with front end damage will likely also involve damage to the shrouds. Perhaps best case is finding ones with large major cracks, instead of tiny little pieces, and epoxy them back together?
Been there. Good luck.
Old Aug 15, 2022 | 11:39 AM
When I posted my response both shrouds were available, but over $200 each
Mcahillmcelroy
Dec 20, 2021 10:06 AM
Davidh3
Jan 15, 2011 08:27 PM
summit
Oct 10, 2010 06:46 AM
4reyes
Dec 2, 2008 06:55 PM
importkiller
Sep 6, 2007 11:08 AM
