ran without oil
Old Jul 20, 2022 | 08:23 PM
kwoodoak's Avatar
Angry ran without oil
Ran H3 without oil! Making bad rattle and leaking now. Is it ruined?
Old Jul 20, 2022 | 08:44 PM
CRKSFT still rotates, fix the leak, refill, drive on.
Old Jul 21, 2022 | 08:55 AM
You leak likely was the reason it lost oil. Like hummerz said...........fix the Leak. If it were me, I would fix the leak, drain whatever oil you put in, change filter, then refill.
Old Jul 21, 2022 | 10:00 AM
is it rattling and leaking oil because a piston shot out of the engine block?
Old Jul 21, 2022 | 12:51 PM
Happy Hummer's Avatar
That is a fantastic question. Because if you aired out the block no amount of oil filling will help. If allz well just follow the other stuff above.
Old Aug 13, 2022 | 03:26 PM
kwoodoak's Avatar
Default ran with no oil
H3 ran with no oil. It made a big noise stopped filled oil. It drives but now leaking the oil is it broken
Old Aug 13, 2022 | 04:58 PM
kwoodoak's Avatar
Ok now the oil we put in all came out once we parked
Old Aug 13, 2022 | 04:59 PM
kwoodoak's Avatar
The problem was me. Didn't check the oil
Old Aug 13, 2022 | 05:30 PM
All came out? Did you check oil pan/drain plug?
Old Aug 13, 2022 | 06:41 PM
kwoodoak's Avatar
No I didn't. I was too disgusted. But I will.
