BG Engine Flush and Oil Change
Old Mar 3, 2017 | 11:19 AM
user 956363738's Avatar
Banned
Default BG Engine Flush and Oil Change
I'm going to take my H3 in soon for the BG engine flush. I also was going to do the oil change myself. I wanted to know if there is a specific order I should do those things? Should I do the engine flush first then oil change or the other way around?
Old Mar 4, 2017 | 09:32 PM
WR3NCHE4D's Avatar
They do them at the same time. You put the cleaner in the oil and run the engine at fast idle for half an hour. Drain the oil and remove the filter. Some places have a machine that connects to the filter housing and pushes remaining old oil out and re-primes the system with fresh oil. Install fresh oil and oil filter. Done.
Old Mar 5, 2017 | 07:21 PM
Happy Hummer's Avatar
Conversely, you can just do a quart of trans fluid and drive for a few day. Then drain it! New filter and oil and your good.
Chris
Old Mar 5, 2017 | 09:05 PM
WR3NCHE4D's Avatar
That is the old school thinking Happy. Doing the trans fluid clean works at keeping an engine clean. Not saying it's bad, just not as good as the BG service. The BG performance oil change gets a dirty engine clean. It removes build up in galleries and ports. I've seen that stuff work wonders on oil burning Honda's and get the stuck variable valve timing on Ford's working again.
Old Mar 6, 2017 | 11:38 AM
My favorite word... "It works". "It's cheap". Lol
greg260
Jan 27, 2018 12:41 AM
2005H2
Jul 12, 2017 02:39 AM
jsbihn
Apr 27, 2014 09:24 PM
rhill20
Jul 1, 2013 12:23 PM
ftc-garage
Dec 29, 2012 08:38 AM
