ABS Failed, etc.
Old Dec 6, 2019 | 06:36 PM
  #41
H32006's Avatar
Just make sure you give them the code in case it doesn't return. They will know where to look.
Btw, did you ever find when the last time your rear diff fluid was changed? Some recommend as low as every 12k miles. Clean fluid is a good thing, especially when the odometer rises. Preventive maintenance is the key to longevity.
Absolute agita!
I have not been back for a while, but the H3 was diagnosed by GM dealer, that pulled and cleaned the ABS, the crunching of the brakes still persist.
There is no error code being thrown.
Just sunk another $2K into the H3:
Oil Change
Rear Brake pads / resurface rear rotors
Right front axle boot
Front lower ball joints
Was not expecting the above.
Got it back and now the interior dash lights are not coming on and the brakes are still crunching.
Again no error codes.
Old Dec 6, 2019 | 07:15 PM
  #42
Originally Posted by H32006
Absolute agita!
Oil Change
My calculated charges should be:
Oil Change $49.99 (Full synthetic + free tire rotation)
Rear Brake pads / resurface rear rotors ($119.99)
Right front axle boot ($199.99)
Front lower ball joints ($299.99)
How did this turn into a $2k repair? Post a pic of your receipt.
Chimpy
Nov 26, 2017 02:59 PM
Crash Gear
Sep 22, 2013 04:51 PM
sysco1hummer
May 24, 2011 08:55 PM
BOSS1705
Oct 16, 2008 11:22 PM
