07 Hummer H3 making noise when turning on front passenger side.
Old Dec 6, 2019 | 10:37 AM
Hummerh3famman's Avatar
Default 07 Hummer H3 making noise when turning on front passenger side.
Last weekend I took the kids to the river through the mud holes with the Hummer. Nothing to deep and I didn’t dog it or anything. I believe the deepest spot what mid way on the wheels. Heading home I noticed a clanking/grinding sound in the front passenger side. I have inspected it and cannot seem to find the issue. At first I thought mud was lodged in somewhere. Now I’m thinking it my be my cv axle. Any ideas??
Old Dec 6, 2019 | 10:44 AM
check your wheel bearing as well and ball joints
Old Dec 6, 2019 | 02:43 PM
MOVED from the wrong section. HF Help & Suggestion Center, like it says at the top of that section is NOT for vehicle questions, but is for questions/suggestions on how to use forum features, like posting a pic, etc....
All H3 questions go in the H3 section.
Get under and do a visual inspection of the half shaft CV joints and boots. A common thing is to get a rock or debris stuck in behind the brake shield that either makes contact with the rotor or the wheel itself when rotating and then makes a racket until it falls out or you remove it.
Old Dec 6, 2019 | 04:21 PM
Sam!'s Avatar
may have bent an brake dust shield.
Old Dec 6, 2019 | 04:54 PM
Old Dec 7, 2019 | 07:01 AM
Get under and do a visual inspection of the half shaft CV joints and boots. A common thing is to get a rock or debris stuck in behind the brake shield that either makes contact with the rotor or the wheel itself when rotating and then makes a racket until it falls out or you remove it.[/QUOTE]
This is what I was thinking. Has to be something small because I previously had no problems what’s so ever. I planned to wake up this morning to work/take a look ,but unfortunately it is raining. I’ll keep y’all posted. It will be either after the rain or tomorrow. Thanks for the suggestions y’all.
Old Dec 7, 2019 | 05:50 PM
wpage's Avatar
Sounds like you got some junk in your boot or other...
Get the power washer out and do some spray and pray...
Ozh3
Dec 5, 2019 10:23 AM
Doc Olds
Jun 6, 2017 11:35 AM
Billarmao
Sep 28, 2016 04:45 AM
AllToreEGo
Sep 27, 2011 12:05 PM
GorillaH2
Oct 30, 2007 11:09 PM
