ABS Failed, etc.
Old Sep 11, 2019 | 11:52 AM
  #31
vacman's Avatar
thank you, dang it I thought i researched that purchase lol
Old Sep 14, 2019 | 01:38 PM
  #32
vacman's Avatar
p0137 o2 circuit low voltage, c0050 rr wheel speed sensor, c0131 abs/tcs system pressure circuit malfunction, c0268 pump motor circuit shorted, c0276 tcm communication performance, u1000 class 2 data link malfunction are my codes, shall i burn it ? lol
Old Sep 14, 2019 | 02:43 PM
  #33
Clear ALL codes and test drive. Scan again after. Post the results
Btw, there is a short to the RR(passenger side rear) sensor, depending on what codes return, you will need to diagnose if it's wiring or the sensor. Visual inspection of the wiring looking for damage, or disconnect the connector to the RR sensor (inside wheel well liner on top of frame) to narrow down the source.
Old Sep 16, 2019 | 10:26 AM
  #34
vacman's Avatar
Looks broke to me
Old Sep 16, 2019 | 03:36 PM
  #35
Same sight I had last year, attempting to pull the lr sensor. Take your time removing so nothing falls into the axle.
Hook and picks, sand paper, pb blaster, brake clean, and a drywall screw, to pull it out. Make sure you have a replacement on hand too, since the axle will be open when you remove.
ABS/TRACTION light came on, I traced it to the drivers side rear abs sensor.
Removed the bolt that holds the sensor into the rear axle and while removing the sensor, it broke,
flush with the axle housing. I had to chip away at it, scrape off a rust ridge that was preventing it from sliding out.
Then inserted a screw into it and popped it out.
Total time:1.5hr, total cost: $53.99 with tax and next day shipping.
Abs & Traction control operating again. '07 with 90,198 miles.
Old Sep 19, 2019 | 07:45 AM
  #36
vacman's Avatar
now wont start , trying to reset key
Old Sep 19, 2019 | 11:54 AM
  #37
vacman's Avatar
finally started yay! abs stab lights out for now, time to trade in lol
Old Sep 19, 2019 | 12:18 PM
  #38
Nice work. What was the source of no start?
Btw, if your serious about selling let me know, I'm only 13miles from westlake.
Old Sep 19, 2019 | 01:07 PM
  #39
vacman's Avatar
had to do the key relearn, ill check its the wifes but I picked up a rav4 she drives all the time, will let u know thanks
Old Sep 19, 2019 | 03:52 PM
  #40
clean/properly secure the connector at the ignition switch.
