2008 Hummer H3 Will Not Run At My Wits End Need Help!
Old Jul 17, 2023 | 03:56 PM
  #31
jws123's Avatar
The whole fuse box was swapped with another so cant be the issue I have un plugged and re plugged in replays fuses so many times swapped things around un plugged whole harness re installed It looks like most people just get lucky and its a relay or box.
Old Jul 17, 2023 | 04:34 PM
  #32
With engine running did you verify proper voltage at fuse #46?
Old Jul 17, 2023 | 05:01 PM
  #33
jws123's Avatar
Shows 14v When running
Old Jul 17, 2023 | 05:13 PM
  #34
Did you verify same voltage at the pcm?
Old Aug 18, 2023 | 09:45 AM
  #35
jws123's Avatar
Well i 100% ruled out the fuse box I took it all the way apart its clean. I just ordered a dash harness off of a parts truck since mines been messed with alot if that fails. Im removing the entire harness from the engine bay to inspect it I almost had this truck sold a few times but people are a pain in the *** so i give up at this point its just a challenge im going to make this Fking thing run and drive then sell it probably break even.
Old Sep 1, 2023 | 08:30 PM
  #36
jws123's Avatar
Welp I finally gave up cut my losses trucks gone thanks for the help tho. If i ever get another hummer its going to be a old one with the least amount of eletronics possible lol.
Bonairesurf
Jan 29, 2022 09:53 PM
Mike Bennett
Apr 26, 2019 08:26 PM
RedTrio
Jan 8, 2019 09:55 AM
Neil.welsh@jims.net
Oct 3, 2017 03:42 PM
