Code P1682
Old Apr 22, 2019 | 07:47 PM
Mike Bennett's Avatar
Default Code P1682
Hi all, new to the forum so take it easy, went for a drive up to the Flinders Rangers in South Australia on the weekend , 4 hour drive to do some 4wd, going up the first decent hill and the Hummer starts missing, goes into reduced power mode and throws code P1682. reset the code and it drives fine until I put it under load at low revs and does it again. We don't have too many Hummer experts down under so any advice would be appreciated. 2008 Hummer H3 3.7 auto.
cheers Mike
Old Apr 22, 2019 | 10:58 PM
Happy Hummer's Avatar
Here you go. Google is great for stuff like this.
https://www.autocodes.com/p1682_chevrolet.html
Old Apr 23, 2019 | 06:22 PM
Default Code P1682
Thanks Happy, I had already looked up the code but was hoping someone may have experienced similar symptoms so i have an idea were to start looking.
cheers
Old Apr 23, 2019 | 08:05 PM
@ the ignition switch, unplug connector, clean contacts with electrical contact cleaner, coat contacts with dielectric grease, reconnect. If that does not correct the problem, replace ignition switch. GL
Old Apr 25, 2019 | 08:48 PM
Thanks hummerz, will give it a go on the weekend
Old Apr 26, 2019 | 08:26 PM
Mike Bennett, Just don't go to extremes for a simple fix! GL
hummer_on_fumes
Jun 21, 2018 01:10 PM
pikappapp
Dec 24, 2017 12:19 PM
hummermongolia
Oct 4, 2015 07:55 PM
mephis2012
May 4, 2015 10:21 PM
ken haukaas
Jan 11, 2011 08:14 PM
