2006 H3 not shifting and speedometer not moving
Old Jul 23, 2021 | 10:00 PM
daveg2022's Avatar
Default 2006 H3 not shifting and speedometer not moving
My 2006 H3 is not shifting and the speedometer is not moving. I have to manually shift to 1 to move off. When in 1 vehicles feels as 2. This issue popup today.
Prior to that the vehicle has been stuck in 4WD. I have problems with the wheels locking up while turning. I was getting ready to change the TC fork. Any advise welcome.
Old Jul 24, 2021 | 03:18 PM
transfer case can be stuck in neutral.. check the shift fork or actuator motor
Old Jul 25, 2021 | 07:49 PM
daveg2022's Avatar
Solved. We changed TC forked and 4WD is working well now. The plastic fork was worn out as others suggested. We cleaned the Speed Sensor on the TC and cleaned the filter in the TC. The vehicle is changing fine again. Seems topping up the TC with fluid affected the speed sensor.
Old Jul 26, 2021 | 08:27 AM
If you do not properly seat the T Case speed sensor, you get the symptoms you had.
Cdelriojr
Apr 15, 2020 10:54 AM
happythree
Jan 25, 2020 08:38 PM
Adrianandy
Oct 1, 2019 05:43 PM
blharty
Jul 18, 2016 08:28 AM
H3 PIlot
Jun 10, 2012 11:55 PM
