H3 2006 transmission install.
Old Sep 30, 2019 | 10:01 PM
Adrianandy's Avatar
Default H3 2006 transmission install.
I have been working on a 2006 h3 first it was just to change the shift solenoid out then after inspecting the pan the transmission was toast there was metal and tranny fluid was black and burnt.there was a high rev after 35mph so the owner bought another transmission to be installed so I installed the transmission everything went on smooth but after all said and done started it up let it warm up and then attempted to shift in reverse ...nothing. Drive ...nothing all gears no shift at all..so we went over again with a fine tooth comb lol attemted again to no surprise still no shift in any form ..what can it be ?fluids are on spot ..
Old Sep 30, 2019 | 10:06 PM
did you reuse the torque converter?
Old Sep 30, 2019 | 10:18 PM
Adrianandy's Avatar
No not the same one from the old tranny we used the one from the transmission he bought.
Old Oct 1, 2019 | 11:40 AM
then maybe the replacement transmission has a failed pump. you might have to check the line pressures.
Old Oct 1, 2019 | 05:43 PM
RKSmith163's Avatar
Is your Transfer Case in Neutral? Simple things first.
blharty
Jul 18, 2016 08:28 AM
ollied
Nov 8, 2014 01:22 PM
rsm688
Nov 6, 2014 05:28 AM
stinger95
Feb 5, 2011 08:51 AM
HummerH2
Mar 13, 2008 12:04 PM
