07 H3 radio ?'s
Old 08-23-2013, 11:50 AM
k3mcfarland's Avatar
Default 07 H3 radio ?'s
I have an 07 H3 with a single disc factory cd player. First, it has the XM shark fin antenna on the roof but when going though the bands XM doesn't come up??? Also I've seen factory H3 6 disc cd players on ebay, is it possible that they would swap out and just need programmed by a dealer to make it work? or am I stuck with the single disc?? honestly, if I could get the xm working i'd be a happy camper! any help would be appreciated!!! thanks!!
Old 08-23-2013, 01:50 PM
happythree's Avatar
the 6 disk will not exchange, different cabling. xm is not in the am fm radio. its separate.
you should look at a wiring diagram or get help at a shop
Old 08-23-2013, 01:56 PM
telemike's Avatar
Old 08-23-2013, 02:46 PM
You have the same radio I have, I added an ipod adapter and I'm fine with it.
As was said, you need a XM reciever which can stand alone and plug into the radio Aux like the ipon adapter, or a head unit with XM built in.
The biggest difference between your radio and the 6 disc changer is your radio has a built in amplifier, the 6 disc uses only low powered speaker outputs and needs an external amp.
Old 08-27-2013, 06:03 PM
Thanks For The Input Guys!
bayrat394
01-23-2011 04:30 AM
alphadogg
37
07-27-2008 08:19 AM
HERHMR
05-05-2008 06:49 AM
crank
06-15-2007 12:05 PM
Xtreme
02-21-2007 08:27 PM
Quick Reply: 07 H3 radio ?'s
