07 H3 Ignition Switch Replacement Video
Old Jun 3, 2021 | 09:58 PM
L_Wiser's Avatar
Default 07 H3 Ignition Switch Replacement Video
Looking for a video that shows how to replace the entire ignition switch. I need to remove the key lock cylinder, the cylinder housing and the switch and replace it with a new one. Can't seem to figure out how to get the old one out. Thank you for your time.
Old Jun 3, 2021 | 10:31 PM
The ignition switch is mounted to the housing for the lock cylinder. Housing requires steering wheel removal. Make sure to disconnect battery, to prevent srs deployment.
Old Jun 4, 2021 | 06:33 AM
L_Wiser's Avatar
I pretty much assumed that would be the case, which is why I was hoping to find a video of the procedure. I'll give it a shot without it and see how it goes - perhaps I'll make one while I'm at it.
Thank you for the info and srs reminder.
Old Jun 4, 2021 | 10:56 AM
You got your chain pulled......
The switch is under $45 and takes about 10 minutes to change.... a two screw and do.
A link to a thread with all you need to know. Ignition Problems
Eddie 70
Jan 20, 2021 10:19 AM
Mike Sandelier
Dec 9, 2019 01:08 PM
jamesb1516
May 4, 2014 08:36 PM
