07 H3 Ignition Switch Replacement Video
Looking for a video that shows how to replace the entire ignition switch. I need to remove the key lock cylinder, the cylinder housing and the switch and replace it with a new one. Can't seem to figure out how to get the old one out. Thank you for your time.
I pretty much assumed that would be the case, which is why I was hoping to find a video of the procedure. I'll give it a shot without it and see how it goes - perhaps I'll make one while I'm at it.
Thank you for the info and srs reminder.
You got your chain pulled......
The switch is under $45 and takes about 10 minutes to change.... a two screw and do.
A link to a thread with all you need to know. Ignition Problems
jamesb1516
May 4, 2014 08:36 PM
