07 Adventure package build thread
Old Feb 25, 2023 | 04:13 AM
  #71
Disel's Avatar
Originally Posted by Lord_Vien
I have 2 spal fans 16 inch each definitely cools enough. My temps never go past 180 at 95 degree weather. I used a davies craig fan controller. But I also have a 160 degree tstat as well.
thermostat at 160F is very cold for this engine. I live where there is winter with frosts.
Optimal set to 186F as you have above.
PWM control unit (I did it myself), smooth switching on and off depending on the temperature. Fans from the Chrysler C300.
The photo of the engine shows that there is no manifold for air (between the damper and the filter). You put just a straight thick pipe. For what?
Old Feb 26, 2023 | 03:27 AM
  #72
wpage's Avatar
My scan gauge reads at 195 when warmed up. Sometimes runs higher in sumer...
My tow reel does block some of the air flow to radiator.
Old Feb 27, 2023 | 10:39 PM
  #73
Lord_Vien's Avatar
160 runs just fine, it doesn't mean it's going to run at 160, it just means it opens faster. And I have a fan controller so I control the temperature based off that like I said no issues even at 95 degree weather or even when it's cold out. If it's too cold I can set the fans to come on later so not sure what you mean. And that's not just a pipe that's an Airdoc intake.
Old Mar 16, 2023 | 12:27 PM
  #74
Disel's Avatar
I'm talking about this pipe? What does it give?
Old Mar 17, 2023 | 03:53 AM
  #75
wpage's Avatar
That pipe delivers air from your air filter to your intake manifold to fuel mix for cylinder combustion....
Old Mar 17, 2023 | 06:56 AM
  #76
Disel's Avatar
I know what it's for. this is the original? Or did you buy separately? I have not seen H3 with such a pipe.
Old Mar 21, 2023 | 12:26 AM
  #77
Disel's Avatar
Hello. please tell me - why did you put it? Does it collect a lot of oil from the engine?
Old Mar 21, 2023 | 08:39 AM
  #78
Looks like an AIR DOC intake tube.
https://airdocintakes.com/product_one.htm
The other is a breather & catch can for crankcase ventilation gasses.
Old Mar 24, 2023 | 09:21 PM
  #79
Disel's Avatar
I know what is it.
But why install it? What will be improved in the car?
Does the oil separator (catch can for crankcase ventilation gasses) catch a lot of oil? And why is there oil? The engine has a native oil separator.
Lord_Vien
New Member Area
Jul 11, 2020 11:08 PM
Synthetickiller
Mar 20, 2015 10:07 AM
Bgmacaw
Jul 9, 2011 07:25 PM
adventurous
23
Jan 5, 2009 07:01 PM
hoggrl
24
Apr 7, 2007 03:11 PM
