06 h3
Old Sep 10, 2019 | 07:39 PM
tdees98's Avatar
Default 06 h3
I am looking at buying a 06 H3 with 92k miles on it. I been looking around and found out about the cylinder head issue and the VIN# range effected ,which this truck fall into. The truck has a check engine light on so when I did the test drive I went by Autozone and had the code checked which shows to be a O2 sensor. The truck runs and drives great so now I am not sure what to do because I was ready to go on it.
,Looking for opinions is it work it or should I walk away?
Old Sep 11, 2019 | 10:52 AM
Run a car fax on it or check the vin# with a GM dealer to see if the head was already replaced. More than likely, it was either replaced or by this time it would already have symptoms regarding the old head. Not every 2006 H3 in the vin# range will experience the problem.
H3ummer
Mar 12, 2014 10:30 AM
newtohummer
Dec 2, 2011 06:31 PM
FloridaFeMan
33
Jun 6, 2010 04:12 PM
archerace7
Aug 12, 2009 09:54 PM
SUPER_CHEVY
Nov 20, 2007 05:19 PM
