Factory chromed wheel corrosion
Old Sep 10, 2019 | 06:12 AM
Peterk's Avatar
Default Factory chromed wheel corrosion
I bought my 2010 hummer h3t back in 2015, noticed slight corrosion. It has got worse. Is it a case of the wheel balance peg causing it ?
Old Sep 10, 2019 | 10:34 AM
most likely yes it is the lead balance weights reacting to the chrome finish especially in wet salty conditions
Old Sep 10, 2019 | 10:59 AM
Peterk's Avatar
Thanks; bi-metal problem, a necessary evil . Or a shaky ride
Old Sep 12, 2019 | 07:20 AM
Have your tire shop remove the outer lip mounted weights. Many better shops will not even try to put those on nicer wheels and will instead use tape on weights on the inside of the wheel instead. Depending on the balancing machine and how out of balance they might stick some as close to the outer face of the wheel while some might be towards the inside edge. They can generally get them in balance just using the stick on weights on the inside though.
Helga She Is Fine
20
Jan 5, 2013 05:33 AM
GunEmDown10
Sep 7, 2012 02:36 PM
Zlee
Oct 6, 2009 12:38 PM
Zlee
Oct 6, 2009 12:36 PM
jrbnc
Nov 27, 2007 12:38 PM
