Wheel speed sensor
Old Jan 3, 2022 | 11:49 PM
Back40coffee's Avatar
Default Wheel speed sensor
I am looking for a rear wheel speed sensor for our 2008 H2 anyone know where I can get one I have tried everywhere online with no luck will one that goes on a 2007 work ?
Old Jan 3, 2022 | 11:54 PM
Default Sorry
I did not introduce my self I am new to the hummer world and thought I would join a forum for some help
Old Jan 4, 2022 | 04:21 AM
oceanbrave's Avatar
RoackAuto has this one. Their site is very useful either for buying or checking part numbers etc
Please double check you model year
Old Jan 4, 2022 | 07:56 AM
calif phil's Avatar
You can also call your local Chevy / GMC dealers parts department and give them the last 8 digits of your VIN and ask if they have one or can get it for you.
My dealer is really good and if they don't have the part I need, it's usually here the next day,
Old Jan 4, 2022 | 08:59 AM
oceanbrave's Avatar
.oops just realised RA are out of stock too..
Comparing 08 and 07 they do look different.
07
08
You're right they are hard to find.
Not 100% on the GM# but it could be AcDelco 19257479
Found theseAgain please check all the details.. others on the forum may be able to help you better
Old Jan 4, 2022 | 12:27 PM
Thanks I tried autozone but will try the others that were suggested all the sites that I have been to show it and then when I put it in the cart it either says nit available or back ordered and thanks for the two pics I can see they are different . As anyone had one of these stuck in place before
Old Jan 4, 2022 | 12:57 PM
Default Tried
Ordered one from summit racing and after I ordered it I got an email that they are back ordered and the best date is 1/25/22 carquest had two one in Michigan and one in Wisconsin so I took both of them we will see if I get one every place I tried does not have them at carquest they told me that they are having a hard time getting alot of things Thanks for the help I am sure I will have some more questions
Old Jan 4, 2022 | 05:35 PM
Contact NTK: GM OEM SUPPLIERS
NTK 72232 AB0214 ABS Wheel Speed Sensor
SKU #AB0214
ITEM #NTK72232
POSITION(S) REAR
BRAND NTK
Old Jan 4, 2022 | 05:56 PM
Thanks I tried all the part numbers I had about 8 different numbers and I could not find one to be had our local carquest was able to find two in there stock in two different states but I ordered both also has anyone had one of these really stuck I am not sure how I am going to get this out as of yet been soaking with oil for a week and still cannot budge it any suggestions Thanks
Old Jan 4, 2022 | 07:00 PM
Remove the connector & bolt. Use locking pliers, (aka:vise grips ; petersen/irwin) clamp tight to the base, closest to the differential. Slowly rotate the sensor back and forth, soaking the joint with penetrating oil(I prefer Kroil & PB B'laster). When the sensor moves freely rotating, start prying under the mount base and keep rotating until the sensor pops out.
Patience Is One Key To Success.
