Typical small & large Vacuum leak locations
Vacuum leak code came up on the code reader. I pulled off the vac sensor on top and tried to blow through it, and suck through it, did not work. You Tube video suggested that. Without elect. Going to it, it is shut, reportedly.
Other suggestions??? Where to check?? The gas cap warning pops up a lot. I checked it and put silicone lube on the rubber seal, it still pops up. ??????
Any ideas????? Thanks
Sometimes just detaching your battery and connecting it again will get rid of some of these warning codes.
What code is it throwing? Get a cheap scan tool
or similar -
Once you have the code Im sure one of us can help
Again without code, you are guessing -
Sounds like you checked the vapor canister purge valve (on top of engine), not blowing through- I would guess its OK.
On drivers side frame rail - You have the vapor canister vent solenoid & the charcoal canister. (check code to see if this could be culprit- both are cheap on amazon & AC delco).
crc2k
Jun 27, 2017 08:09 AM
KruBruder
Feb 22, 2012 07:35 PM
