Typical small & large Vacuum leak locations
Old Jan 23, 2024 | 08:50 AM
niartsJT's Avatar
Default Typical small & large Vacuum leak locations
Vacuum leak code came up on the code reader. I pulled off the vac sensor on top and tried to blow through it, and suck through it, did not work. You Tube video suggested that. Without elect. Going to it, it is shut, reportedly.
Other suggestions??? Where to check?? The gas cap warning pops up a lot. I checked it and put silicone lube on the rubber seal, it still pops up. ??????
Any ideas????? Thanks
Old Jan 23, 2024 | 08:51 AM
niartsJT's Avatar
2007 h2
Old Jan 23, 2024 | 10:42 AM
BLK WLF's Avatar
Did you try to reset the OBD?
Sometimes just detaching your battery and connecting it again will get rid of some of these warning codes.
Old Jan 23, 2024 | 10:53 AM
rotted fuel pump can give evap codes.
Old Jan 23, 2024 | 01:22 PM
Gavin Costigan's Avatar
what's the code. Evap and vacuum are two different things. Very common is the vent solonoid to go out.
Old Jan 24, 2024 | 07:36 PM
Chrmer3's Avatar
What code is it throwing? Get a cheap scan tool
Amazon Amazon
or similar -
Once you have the code Im sure one of us can help
Again without code, you are guessing -
Sounds like you checked the vapor canister purge valve (on top of engine), not blowing through- I would guess its OK.
On drivers side frame rail - You have the vapor canister vent solenoid & the charcoal canister. (check code to see if this could be culprit- both are cheap on amazon & AC delco).
zc101
Jan 11, 2024 02:17 PM
crc2k
Jun 27, 2017 08:09 AM
pmedic242000
Jul 1, 2014 07:17 PM
Alex2012
Oct 16, 2012 03:39 PM
KruBruder
Feb 22, 2012 07:35 PM
