Gross EVAP leak, no codes, gas smell
Old Aug 18, 2011 | 09:12 PM
KruBruder's Avatar
Default Gross EVAP leak, no codes, gas smell
I've searched for this but haven't found anything. I know this can't be an isolated incident. This was happening on my last H2 and is happening on this one now. I have a strong smell of gas fumes from my drivers side obviously coming from around my EVAP canister and/or vent solenoid. It's so bad that I get headaches when I sit in the same spot with the truck running. I'm sure I could pinpoint the problem better if I had a code. Anyone else have this happen? Just wondering if I got mud in something, how I can fix it, and why I don't throw a code. '03 H2 Adventure.
Old Feb 22, 2012 | 01:12 PM
redlx50's Avatar
I have this happening on mine as well. I haven't tried to track it down yet. I did put a complaint in at safecar.gov about it. Should be something GM has to fix since it seems like a safety issue.
Old Feb 22, 2012 | 07:32 PM
coachwesh2's Avatar
evap leak problems happen all the time and not only on hummers . all cars have it and can be in several areas. there is a green cap on a vacuum line under the hood and can be used to pump air into it to listen for a leak with a hand pump . it dont hold a lot of psi about 7-10 psi. this system is complex and most times it sets a code if a part fails but if a line is open it will just say evap large leak. . small leaks are in most cases a bad cap. will look for the exact text to check for the leak in the am . some cars must be running and have over a 1/4 tank and strange things like that. most real scan tools cant test the solenoids . we use a smoke machine to find the leaks .
Old Feb 22, 2012 | 07:35 PM
coachwesh2's Avatar
for now follow the vent line coming from the fuel tank and follow it up to the engine compartment just to see it you have anything unplugged or split open.
zc101
Jan 11, 2024 02:17 PM
big gulp
Oct 27, 2013 07:34 AM
SwillRacer
Jan 19, 2013 08:11 AM
italia147
Oct 31, 2010 10:05 PM
Gooch
Jun 26, 2008 10:38 PM
