Transmission only shifts manually.
Old Dec 9, 2025 | 10:25 PM
  #41
Gavin Costigan's Avatar
Originally Posted by Loco
Thank you so much I really appreciate it i just needed to be pointed in the right direction i dont plan on getting rid of my H2 so i want to fix it right now matter what.
np263 and controller should play nice with your electronics and be a direct bolt in. If not just keep your existing shift motor and zip tie it to the side. May have to change the driveshaft length but any driveshaft shop will do that cheap.
Old Dec 10, 2025 | 12:35 PM
  #42
from the pictures that you posted do you even have a front differential? you might not need a transfercase at all at that point. just a 2 wheel drive transmission and a rear axel to suit. 4l80 is not a direct bolt on. it is longer and needs transmission crossmember modifications. it might also require a 1" body lift to clear the bell housing.
Old Dec 10, 2025 | 01:34 PM
  #43
Loco's Avatar
No there's no front differential
Old Dec 10, 2025 | 01:53 PM
  #44
so you will not need a transfer case or a 4 wheel drive transmission.
Old Dec 10, 2025 | 01:54 PM
  #45
Loco's Avatar
What transmission cam i use?
Old Dec 10, 2025 | 02:02 PM
  #46
4L80E, and the modern 6L80/6L90 need computer, plus manual (stick) options like the T56 Magnum or old school 4L60E, TH400, 200-4R, TH350, Powerglide. there are also adapters for other transmissions. tremec and such.
Chatfield
Mar 27, 2023 10:03 AM
Arsalan
Oct 14, 2021 11:28 PM
blharty
Jul 18, 2016 08:28 AM
Zeppelin
Jun 20, 2016 04:07 PM
dizzy
Aug 30, 2007 11:12 PM
