Roofbar spots
Old Oct 7, 2019 | 03:32 AM
chevykev's Avatar
Default Roofbar spots
Putting 5 halogen spots on roofbar, would it be ok to wire them all together or better on 2 separate switches / relays
Old Oct 7, 2019 | 06:53 AM
The factory setup of the optional halogen roof lights wires them all together.... The key is that the main power wire to the lights and the relay can handle the current.
Old Oct 7, 2019 | 01:27 PM
LoJac963's Avatar
All depends on the lights and how much amperage they are pulling. My first question would be why not LED vs halogen? Lower amp draw and depending on the brand can be just as good if not better than old school halogens.
Old Oct 7, 2019 | 02:16 PM
chevykev's Avatar
Default Spots
Thanks for replies. The lights are 55w & were freebies. Think I'm going with them all together with suitable size wire etc
Old Oct 9, 2019 | 11:42 AM
LoJac963's Avatar
Got ya. Probably need fairly hefty wiring to feed those bad boys. Definitely use a relay setup for the main power feed and ground with a simple 12V feed to an interior switch. You can use an "add a fuse" on the interior accessory fuse to feed any switches within the interior. That is how all my lights are setup.
dukie748
Jul 26, 2015 10:02 PM
lovemshaved
May 16, 2013 05:44 AM
lucky19942001
Feb 12, 2008 08:52 AM
bmbenear
Jul 17, 2007 06:31 AM
jbb6811
Nov 21, 2006 07:05 PM
